Януари 2018
 123456
78910111213
14151617181920
21222324252627
28293031
 Как да изпратим данни от Pro/E към Excel?
Предишната тема Следващата тема Go down
ПисанеЗаглавие: Как да изпратим данни от Pro/E към Excel?   Вто 13 Май - 14:53:02
Extracting point data from your Pro/ENGINEER models can be a cumbersome task, especially if you follow the suggested PTC export/import process. This can be streamlined significantly using Pro/WebLink, but also with J-Link and Pro/Toolkit.
I've discussed, in previous articles, obtaining lists of features and recursing through assemblies. What's different here is that a transformation matrix will be used to obtain the XYZ position of the point with respect to the default coordinate system of the assembly. This is the position data that will be output to Excel.
The HTML page has a single button, which initiates the point data extraction, and a single div field for some results. Library files pfcUtils.js and pnts2excel.js contain Javascript code. pfcUtils.js is a utility library provided by PTC. The code discuss in this article would be contained in the pnts2excel.js file.
<HTML><SCRIPT LANGUAGE="JavaScript" type=text/javascript src="pfcUtils.js"></SCRIPT><SCRIPT LANGUAGE="JavaScript" type=text/javascript src="pnts2excel.js"></SCRIPT><BODY><form name="f"> <INPUT name="a" type=button value="Get Point Data!" onclick="GetPoints()"> <br><div id="mesg"></div><br></form></BODY></HTML>
After the GetPoints() function has obtained the session object and verified that a model is active, it sets up an object used for some persistent data and for returning an array of points.
The object has the following properties: modelsFound (array), points (array), root (top-level model object), comppath_seq (intseq object) and transform (assembly tranformation matrix). GetPointData() is called using the current model and appdata object to obtain the point data. Then PntArrayToExcel() is used to send the data to Excel.
function GetPoints () { if (!pfcIsWindows()) netscape.security.PrivilegeManager.enablePrivilege("UniversalXPConnect"); var elem = document.getElementById("mesg"); var modelname = "no model"; var session = null; var model = null; try { session = pfcGetProESession(); } catch (e) { elem.innerHTML = "ERROR: Cannot connect to Pro/Engineer session!"; return; } try { model = session.CurrentModel; } catch (e) { // probably no model elem.innerHTML = "Problem getting current model info."; return; } elem.innerHTML = "<br>" + "Top Level Model: " + model.FileName; // Create appdata object // var appdata = new Object(); appdata.modelsFound = new Array(); appdata.points = new Array(); appdata.root = model; appdata.comppath_seq = new pfcCreate("intseq"); // need 'new', this is an instance object appdata.transform = null; GetPointData(model, appdata); PntArrayToExcel(appdata.points);}
There are two main actions in the GetPointData() function: point extraction, and recursing (for subassemblies). The modelsFound array is used in both actions, and helps to avoid extracting data from a model more than once. In the assignment statement, it is flagging the currently encountered model as having been processed, so that it will not get processed again.
After that, a sequence of points is obtained using the current model and the ListItem() method specifying ITEM_POINT. This will return all points in the model, not just a single feature, which is important if point array features are present in the model. Using the 'Point' property of the point, we can get a Point3D object which has the XYZ info. If there is a transform matrix available, it is applied to the point data first. The model name and XYZ data of the point are assigned to an object, which is then push into the 'points' array property of the appdata object.
In the recursing action, if the encountered model is a subassembly, the code iterates over the component features, if any. If the component is active, the feature id is appended to the comppath_seq sequence, which is used to get the model object from the feature object and the transformation matrix from the root assembly's default coordinate system. The matrix is saved into the appdata object.
If the component has not been encountered already, GetPointData() is called recursively with the component model info. After the function returns, the last element of the comppath_seq is removed.
function GetPointData ( model, appdata ) { var elem = document.getElementById("mesg"); appdata.modelsFound[model.FileName] = 1; // Get points in current model // var points = model.ListItems( pfcCreate("pfcModelItemType").ITEM_POINT ); for (var i = 0; i < points.Count; i++) { var point = points.Item(i); var pnt3d = null; if (appdata.transform == null) { pnt3d = point.Point; } else { pnt3d = appdata.transform.TransformPoint(point.Point); } // send pnt data to the browser elem.innerHTML += "<br> " + model.FileName + ": " + point.GetName() + " (Id " + point.Id + ")" + ", XYZ= ( " + pnt3d.Item(0) + ", " + pnt3d.Item(1) + ", " + pnt3d.Item(2) + " )" ; var object = new Object(); object.Owner = model; object.Point = pnt3d; appdata.points.push(object); } // Recurse into components, if model is an assembly // if ( model.Type == pfcCreate("pfcModelType").MDL_ASSEMBLY ) { var components = model.ListFeaturesByType( false, pfcCreate("pfcFeatureType").FEATTYPE_COMPONENT ); for (var i = 0; i < components.Count; i++) { var compFeat = components.Item(i); if (compFeat.Status != pfcCreate("pfcFeatureStatus").FEAT_ACTIVE) { continue; } // Append id for use in building comppath appdata.comppath_seq.Append(compFeat.Id); try { // Create ComponentPath object to get pfcModel object of component and transform var cp = pfcCreate("MpfcAssembly").CreateComponentPath( appdata.root, appdata.comppath_seq ); var compMdl = cp.Leaf; appdata.transform = cp.GetTransform(true); } catch (e) { elem.innerHTML += "<br> CreateComponentPath() exception: " + pfcGetExceptionType(e); } // Descend into subassembly if ( !(compMdl.FileName in appdata.modelsFound) ) { GetPointData(compMdl, appdata); } // Remove id (last in seq), not needed anymore try { appdata.comppath_seq.Remove( (appdata.comppath_seq.Count-1), (appdata.comppath_seq.Count) ); } catch (e) { elem.innerHTML += "<br> comppath_seq.Remove exception: " + pfcGetExceptionType(e); } } // Loop: components } // model.Type}
The PntArrayToExcel() function sends the data to Excel. The code first tries to use an existing Excel session, but will start a new one if necessary. Certain IE security settings may result in a new session being started every time.
Once an Excel session is available and a new workbook has been created, the code iterates over the 'points' array property of the appdata object to write the data into the active sheet. Four columns are used in the output, which include the model name, X position, Y position, and Z position. Since a particular coordinate system was not referenced, the default coordinate system of the top-level assembly is used.
function PntArrayToExcel ( array ) { var oXL; var elem = document.getElementById("mesg"); // Get/Create Excel Object Reference try { oXL = GetObject("","Excel.Application"); // Use current Excel session } catch (e) { // couldn't get an excel session, try starting a new one try { oXL = new ActiveXObject("Excel.Application"); // Open new Excel session } catch (e) { // couldn't start a new excel session either } } if (oXL == null) { elem.innerHTML = "Could not get or start Excel session!"; return; } try { oXL.Visible = true; var oWB = oXL.Workbooks.Add(); var oSheet = oWB.ActiveSheet; } catch (e) { elem.innerHTML = "Problem creating new workbook."; return; } for (var i=0; i < array.length; i++ ) { var pnt3d = array[i].Point; var ownerMdl = array[i].Owner; oSheet.Cells(i+1, 1).Value = ownerMdl.FileName; oSheet.Cells(i+1, 2).Value = "" + pnt3d.Item(0); oSheet.Cells(i+1, 3).Value = "" + pnt3d.Item(1); oSheet.Cells(i+1, 4).Value = "" + pnt3d.Item(2); }}
Other than the transformation matrix, the code is pretty straightforward and easily adaptable to other data sets (i.e. parameters, layers, feature lists, etc).
Предишната тема Следващата тема Върнете се в началото
